G'day from NZ
1948 Vistas
Hi from the Waikato. I drive a 2004 Camry with a 1MZ-FE that is soon to be twin turbo'd. Currently has the front bank turbo installed and making ~180fwkw and 430nm on 3psi of boost from a TD04L. Just using a Gizzmo CamFC for fuelling and factory ECU knock retard. Has been running like this for ~8,000kms so keen to upgrade and get more power. Soon to get a link g4x atom for it and then adding the 2nd turbo.
Hi Sam great car to play with
hopefully we can see some pics and dyno sheets soon
Hey, look it's the famous DDT man himself! I actually did some work experience there, after you left, got along pretty well with Tony. Yeah this car is quite challenging because there's no aftermarket but that makes it more fun I think
hey ate great to have you on here. yep that tony is a legend
