greetings from ireland
2243 Vistas
Hi guys, new to forum, built new evo4 rally car from scratch, running standard evo 4 engine rebuilt, with new evo 9 80 series turbo, using Links G4 Ecu
Double post
Welcome , I'm all so from Ireland All be it Northern Ireland, I seen ur post about exhaust heat , you would need a wide band air fuel ratio gauge to check the curling on idle man also be sure the timing is set correctly with a timing light
Welcome to the forum, I'm from across the pond in Scotland.
