Hello everyone
1940 Vistas
Good evening from UK I'm a master tech for scania, I have a very modified Ford mondeo St220
Running emerald k6 ecu
Raised comp 11.1, piper cams, forged rods,, diamond racing pistons, balanced engine, oversized . 5 bore, lightweight ttv flywheel,, ap racing clutch from a noble m400 Davies Craig ewp130, E46 m3 teeves mk60 abs unit, aim motorsport strada mxs dash , in process of fabricating inlet manifold and equal long exhaust manifolds
I have basic knowledge already, car has been mapped but since found out the car has pwm fuel pump control, and emerald doesn't support it so I converted it to return style with a deutsch worx regulator
So the map was excessive rich with 10 afr 100% throttle low rpm I'm hoping To learn alot about and this hp academy fits the bill very well!
Hi Liam,
Welcome to HPA, you'll learn a lot quickly here
Thank Chris
