Hello from beautiful Croatia
2194 Vistas
Hey guys!I'm Mario, I'm from Croatia, interested into all cars that exist. I'm pretty good with older VAG group cars and engines.
Cheers!
G'day Mario, welcome to the team! The older VAG stuff does have a massive following, what sort of years are you experienced with?
I Spent 4 days in Croatia, rented a Citroen C4 TVR and cruised the Adriatic coast. Welcome!
Hi Mario,
Welcome to HPA, are you tuning anything at the moment?
Jeez never got to answer this, maybe subscribing to topic replies isn't a bad idea.
6 years have passed and a lot of things changed.
@Zac.Perston
I tend to work on engines and cars till 2004 in vw Department and 2008 in Audi Department.
@Chris250
In these last 6years and 7 more(before joy-ning HPA community I've been building and driving old 1986 Vw Scirocco 16v witl 2l block and turbo, and three years ago I disassembled it and now modern TSI engine from golf R is already under the hood. Unfortunatly it still doesnt't run since I'm under heavy influence of Carbon fiber drug. I've set myself a vision and I refuse to go down other route.
Parallel to this last year I've started to build sleeper audi 1.8t that should be able to attack some corners and provide almost instant response with flat tq curve from 3500-7500rpm. This year I plan to get the proof of concept since I'm trying something different now and trying big power difference between stages. HP stage is 330hp turbo and LP stage is 950hp turbo.
Ill open a build thread and I hope that you guys might chine in with more knowledge than myself.
I'm glad you're putting the knowledge to use! Enjoy.
