Hello from Finland (Arctic circle level)
2080 Vistas
Hi I'm Kalle 21 years old and I come from Tornio Finland. Currently a student in a university of applied sciences.
Done some tuning and wiring , hoping to learn a lot new and become a better tuner. Have mostly worked with haltech ecu's (sprint,sport,plug-in).
Currently on works a JZA70 drifter build with build 1jz engine(rods,bolts,bearings, high comp pistons, cams, haltech sport 2000, etc...)
Regards Kalle
Hi Kalle,
Welcome to the forum. What's your target goal with the JZA70?
Hi chris!
Im shooting for a pretty wide powerband from 4000-8000rpm. We'll see what it will produce, should be around 600-700whp. Afterall this is my first engine setup that I've planned.
all the best with the build, be sure to put a thread up in the build section
