Hi from south coast nsw
979 Vistas
Hi my name is Al. I have been it to car my whole life since i could walk. Allways loved hotted up cars and allways wanting to know more about them. Then around the age of 18 i rebuilted a holden 308ci and the rest is history from then on. I currently own a 2007 wrx that i purchased blown up and rebuilded the engine to what i know should be right based on years of researching and working in spare parts. It runs a stock ej257 bottom end with arp rod bolts, 12mm oil pump, acl race bearings. The head has been ported inlet & exhaust to 1.5mm over with 1mm supertec valves, supertec beehive valve springs, titanium retainers, cometic head gaskets, std cam shafts. Running a vf 22 turbo charger, custom intercooler, stock 550cc injectors and modified tgv. Factory base tune was around 322rwhp and 366nm on virtual dyno. Im still learning the tuning side of it as you do everyday bit diffrent to adjusting the screws on the carby or adjusting the dissy. Im trying my hand at ecuflash and also hp tuners. Its a new learning curve but i love a good challenge and love learning new things along the way. Cheers Al
