Remy B. from the Netherlands
1191 Vistas
Hello gentlemens, Remy B. here, I'm dutch raised in South America, and work for the past 25 years as a Gas engine and Compressor Technician with jobs around the world, as well with Diesel engines, all large engines, currently I'm the head of an Engine overhaul shop ( smallest engine overhauled weights 11 ton ) I'm just a car enthusiast, I overhaul and modify my engines on the Toys that I had, currently I'm based in the middle East, my project cars is a Mitsu Eclipse 2G with 4g63t, it is my daily driver, coming mods are 16G turbo, cams and external waste gate, with larger injectors and fuel pump, already installed 2 1/2 size bigger aftercooler ( it is hot hear in middel east ), currently I'm helping a buddy with his build an Honda Civic Hatchback from 92, we replaced the OEM 1.5L engine and we installed a B18C in it, modified brakes, suspension, and slowly some more mods coming, my project car is a Mitsu Colt 97, currently with the OEM 1.5L engine, I have a second 4g63 with manual gear box that is in the plans to take the place of that 1.5L engine, the 4G63 will be NA, the gol is for Trackdays only car just to have fun.
My main gol here in HP is to learn about EFI, I like to do things myself I like learning and reading a lot about pretty much anything to do with motorsports performance and HP seems the right platform to start in the right direction on EFI and maybe other topics.
Welcome and thank you for joining!
