Custom Modified Forged Block Manufacture
Puesta a punto de carreteras
598 Vistas
I am looking for a company I can reach out to them to build custom BBF engine blocks and cylinder heads for me...
It is seemingly difficult to locate and find these businesses...
Some direction and guidance is appreciated, thank you
Are you a member of the Performance Racing Industry (PRI)/ I would look in their magazine, and at the PRI show in December to meet with companies that might be able to assist with your project.
Just flipping through the mag, have you tried:
Brodix http://www.brodix.com
BMP (Bill Mitchell Products) http://billmitchellproducts.com
Assuming you mean big block Ford, if it's something FE series based, there are companies that make them, but when you wrote "forged", I assume you meant billet, rather than cast iron, or alloy?
If so, might be worth checking this discussion on the merits, and problems, people have had with different versions, and different manufacturers/suppliers - https://www.fordfe.com/best-fe-aluminum-block-t162137.html
One of the chaps here has a Shelby block in his Cobra - https://www.shelbyengines.com/products/finished-block?variant=167529822
If you have something else in mind, as the expression goes "If you have the money, we can make it" - but that can be expected to be DEEP into 5 figures!
