Sr20det Idle issue
Puesta a punto de carreteras
2544 Vistas
We got the car running using the Haltech 1000 base map our issue is that when we input the correct injector flow rate (we accidentally fired it up with a stock injector flow rate entered) the car will no longer start
Not sure of the cause on this one, since it is on VE it should scale based on pressure and flow correct?
Pressure is set to 45psi by my gauge
Sr20det solid lifter tomei 270 cams
I have verified timing at crank we cannot get it to 3000rpm so I cannot confirm timing yet
boost piping has been pressure tested with no leaks
all sensors are calibrated and functioning properly
any input would be helpful
