UK heat gun recommendations
Puesta a punto de carreteras
1931 Vistas
The DeWalt, with accurate temperature adjustment doesn’t seem to be available in the UK, as my old heat gun is well past it’s best, I’d like to replace before starting my next loom; any recommendations for UK available (240 Volt) variable heat guns?
DeWalt D26414 has similar temperature settings and should be available in the UK.
Dave, I'd say anything out there with a settable temperature is going to do the job for you. If you're gearing up for a production environment, I'd have a look at Steinel products, for the longevity. If its for the occasional harness for your own projects, I'd go with something a bit cheaper.
