Variable cam map road tuning
Puesta a punto de carreteras
2241 Vistas
How to set or how tu tune a variable cam on the road?
The best you can probably do for wide open throttle is most air demand as seen by measured lambda/afr vs fuel delivery, at cruise you probably need to find somewhere you can do repeated runs and work out lowest fuel consumption while maintaining speed in gear.
