Adjusting values in the fuel or ignition table
Ajuste práctico independiente
1689 Vistas
How do you highlight for example 2000-3000 rpm and cert loan and change numbers by 1-2 or reduce then using the keyboard
Each ECU tuning software may have a different way of doing this. What ECU/software are you using? The help with most software normally has the details of how you do specific table modifying tasks from the keyboard.
