CVT transmission on Dynapack
Ajuste práctico independiente
3448 Vistas
Is it safe to tune a CVT tranmission on dynapack?
I've never tried running one. Maybe someone else on here can add to the thread?
I would simply try running it and see how you get on. In some ways I'd guess it will be similar to tuning an auto trans with a high stall converter which results in the engine sitting in the same area of the rpm map for much of the run. The dyno graph is also a little unusual looking to say the least.
