EGT fault
Ajuste práctico independiente
1582 Vistas
I have just plug in my laptop to the ecu m84 and I have a EGT fault. I have 1 lambda sensor and no EGT what could this mean.
That it is configured for EGT. Look in Adjust->Sensor Setup->Input Setup... EGT is listed as AV6. Be sure the calibration is listed as Predefined/Select Calibration...
Could you could you have a look at my files.
You have EGT configured on AV6 but it's not calibrated (and I assume doesn't really exist). Remove the assigned input and you should have no error reported.
Thanks
