Fueltech K24 Crank Trigger Issue
Ajuste práctico independiente
6836 Vistas
Hi guys,
Im having an issue trying to start a k24 with a FT550 ECU. im getting this errors.""
can you post your map up so we can take a look ad help find an issue, i think a log would also help along with a trigger scope capture
Regards Ross
You can do a scope test with that ecu too, and see what the sensors are actually doing.
Hey I’m having this same issue, was there a resolution?
I just bought a brand new k20 crank sensor
Fuel tech does a very poor job of decoding most triggers and K series especially. Post your trigger settings and we can help. I feel like on some engines the OEM triggers work fine with Fuel Tech but another engine with same settings just will not run correctly.
