POP AND BANG
Ajuste práctico independiente
2165 Vistas
How to i tune the ecu to achieve the pop and bang? like if i let go of the throttle, it does the pop and fire sound. do i have to change my main ignition map for that?
What vehicle is it? Usually it'd be a lot of ignition retard and a richer mixture.
a mitshubishi CS3 (4g18 engine, N/A). Also completely unrelated, how do i install a lambda sensor in link ecu? do i have to use the can lambda sensor (it is so expensive), cant I just install the sensor like how maxxecu does it?
Some Link ECU models have built-in Lambda controllers (i.e. Link G4x Fury, G5 Voodoo Pro), and some require an external Wideband controller. The quality and ease of integration with the Link CAN Lambda make it a no brainer.
Having solid-reliable Lambda data -- Priceless!
