Sensor calibration, Ecumaster
Ajuste práctico independiente
2161 Vistas
Hi! I am finally all done with all the wiring. Currently assigning pins and calibrating sensors.
Engine is 1JZ-GTE VVTiE, ECU is Ecumaster classic
IAT was a success, shows approximately ambient temperature. CLT and Oil temp however are no where near normal with any of the wizard selections. I found documentation with expected values and the VW Beetle wizard option matches. It shows 46°C though, in a cold workshop. Would anyone be able to shed some light on this?
