Slight run on after key off
Ajuste práctico independiente
1939 Vistas
Getting some dieseling on a tad on my r53. What would be the area to look at here? Link g4+
Double check the power to the ECU...it may not be shutting off when you think!
I once had an ECU that kept running after turning the ignition key off...when you turned the ignition off there was a negative voltage at the trigger on the ECU relay which was enough to keep the ECU alive and engine running until fuel pressure dropped off.
The solution was a diode protected relay.
