STEADY STATE
Ajuste práctico independiente
1484 Vistas
Hi, I have access to use a Dynomax Dyno for the tuning process. But I do not see a “steady state” option on the screen. Do I have to look for it with another name?
Is there a "mode of operation" option, with "constant speed" in it? You don't say what model it is, but if it's supported that 'should' be what you want.
I could very well be wrong, though, as I'm not familiar with the machines.
If you mean a Land & Sea/Dynomite dyno (their software is called "Dynomax") then just click the hold button on the console so it is green. To change the hold RPM set point the rough adjust is the left/right arrows and the fine adjust is the up/down arrows.
Thanks for your answers I will check and let you guy's know
