Steady state tunning
Ajuste práctico independiente
1804 Vistas
I was wondering on how you keep it at 2500 rpm in full throttle. can you please explain on how this is done
thank you
Load Bearing Dynos can vary the load, but keep the RPM constant. Inertia dynos don't do that, only ones that have a load-bearing brake. Most Mustang, Dynapack, Mainline, DynoDynamics can do this, but few of the Dynojets have this feature (but there are DynoJet models with load-bearing brakes).
