trigger mode
Ajuste práctico independiente
1291 Vistas
how can we disable the fuel pump?
It would be helpful to have a little more information so that I can give you a proper answer. With nothing else to go on, you could turn off the fuel pump output, remove the fuse, or the fuel pump relay.
