Trigger Tooth
Ajuste práctico independiente
1570 Vistas
I know how to get the Trigger angle - But the trigger tooth - how do you find that? (running 60-2). thanks in advance.
On a 60 tooth wheel, there are (360 / 60) 6 degrees per tooth . So divide your trigger angle by 6 to find the tooth number (or close).
You are the best - Thanks much.
