VE table incorrect?
Ajuste práctico independiente
1606 Vistas
hello everyone, I have a doubt, the VE table when the turbo pressure becomes positive, leads me to decrease the values anczichè increase them. I am attaching the mapping file. another thing, in second gear under acceleration the engine warning light comes on. We did several jumps in third and fourth gear and it didn't happen. some advice? Thank you
  • test-rb25-IGN-BASE.pclr
another thing, the turbo is at 1.4 bar
An engine warning light could mean many things. You should be able to find how to read the code on-line.
Someone can check the funk table please.? The value si high from 100 to 0 and more plower in i ho in positive boost
