2019 6.7 Cummins engine modes
1552 Vistas
Curious how everyone is actually deciphering which modes the engine is referencing timing from? I’m using HP Tuners, I have plenty of parameters to pick from, also have the SOTF OS loaded in. The channels list logs multiple operating modes that it’s in at the same time For example,
mode 0 active- yes
engine mode status-2
engine mode-1
SOTF override active- yes
SOTF slot-4
Im running it in slot 4, but its not showing the timing I have in there, it seems to be referencing mode 0 a lot but i have pilot injection shut off at idle in slot 4 and i hear that, so I know my slot overrides are turned on and work, just very curious and unsure when it seems to be using multiple modes. Or do I have to go in the main modes and change those tables and not just the tables in the slots?
thanks,
Dakotah
