AFR sensor
1688 Vistas
When you run a AFR sensor to log the stoichiometric are you installing a new threaded insert into the exhaust for the sensor?
Hello yes normally we do it depends on what is needed, if the software has a wideband sensor that is able to be logged and or read live then there is often no need for another unit to be used but if you have a stand-alone wideband system them generally another bung will be added
Regards Ross
Thank you for the response!
