cranking quantity injection
1457 Vistas
nick why would you have to raise this for bigger injectors i would think you lower it please explain i am very new to this thanks justin
Some larger injectors flow less than stock at low pressures such as cranking. I've had to add to it before for this reason.
Only other reason I can think of is to get a puff of black on start-up.
-Nick
