E35A variable axis
950 Vistas
Does anyone know if there is a way to change the rpm axis on the fueling and timing tables of an e35a. I’m using EFI live and not finding anyway to do it. If I’ve heard you can edit axis on hpt but don’t want to spend the money to converter a file unless I know for sure. Thanks guys
The only way to do it is to define the axis separately in EFILive using a .cax(8) or edit the axis directly in a suite like tunerpro or Winols. Keep in mind if you edit a .bin in OLS and then import to EFIlive the axis will still display the old values (incorrectly). You may have better luck using HPtuners to edit the axis come to think of it.
-Nick
