Somehow i have hard time understanding this table. Mostly when you modify the axes. Is it that when you modify the last column of the fuel quantity, the ecu also reads it as you write it? I mean if you modify axes volume from 160 to 190, the ecu now reads it as 190 and not the previous 160mm3 or so? And if so, is it enough to modify the last axes only? Can the ecu calculate those lower quantity values also becouse now you have 60mm3 jump from previous axes value? Thanks.
