Lmm tuning
2927 Vistas
When tuning an LMM Duramax or something that has Timing table A B and C for the different altitudes. Do I copy and paste from the chart I made changes to or do I make the same increment of change to each table?
Logan,
You'll have better luck making adjustments using the increment from the first table you were working in.
Nick
