Manual swap
1531 Vistas
I have a 05 Cummins I just did a manual swap in and it has hptuners in it. How can I get it to work so the prndl is off and the alarm don’t keep going off when I start the truck
Not a truck guy, so can't directly help but, if you give some more info' on the truck, there are a bunch of smart chaps who should be able to sort you out.
I dont know if Hptuners can do it for you but you can go to trans on hptuners and change auto transmission from enabled to disabled and see what happens, however smarty s06 can do it you just need to email them and they'll send you the file and prndl will disapper.
attached photo is for reference.
