Im new to building tunes but been around for a min. im working on a 16 ram cab chassis and im having a hard time to get rid of throttle lag/torque management any advice on what and where to make some changes?
Assuming you have the relevant torque limiters raised in the off-idle zone, I would look at the lambda or mixture limit table. I believe the units in EFILive are in equivalence ratio. Regardless, try allowing a 10% richer mixture below 1500 RPM and see if that moves things in the right direction. If I recal the C&C trucks are set up exceptionally lean.
Nick
