VAG Diesel Datalogging?
1130 Vistas
What is the best option to datalog a VAG 3.0L TDI on the dyno??
VCDS from Ross Tech the best option or is there something else out there?
Depends how in depth you want to go with logging. I quite often start with hptuners, just because I like the logger and can get some decent channels on some euro stuff.
Failing that, VCDS is probably a good place to start.
Ben will have to try my HPTuners cables. Was thinking maybe there was manufacture specific PIDs that wouldn't be defined but the all the generic stuff should be there and I am so familiar with the interface. Thanks for the TIP
