wide band location
Módulo relevante: Ejemplos resueltos > EFI Live 2005 LLY Duramax > 4. Optimizar la sintonía
1017 Vistas
i am coming from tuning gas engines and always was taught to have the wideband as far forward as possible, does this same theory apply to diesel tuning ? also can i use the same wideband sensor that i tune my gas engines with ? thanks for the help
I usually put them in the downpipe maybe 6-12 inches past the turbo. They seem to last pretty well there.
Same sensor is okay, yep.
Thank you for the info !
