Wideband Bung Placement
2251 Vistas
How far back in the downpipe do I need to place the bung for the O2 sensor? I assume that right after the turbo is too Close.
Thanks
Closer to the turbo is better, a couple bends back if you think it may spit the turbine :). Wrap the downpipe back to the O2 sensor to conserve heat.
Nick
So if I keep egt on the south side of 1600 I should be ok? :)
Thanks Nick. I'm enjoying the class, love your diesel insights and diesel tuners blog also.
You got it, glad you're finding it all useful!
Nick
