Worked Examples
Módulo relevante: Ejemplos resueltos > Sintonizadores HP para Ford F350 Power-stroke 2017 > Introducción
2027 Vistas
I’m a there any other worked examples of diesel trucks other than the 2? I’m really curious on the process with modified fuel/air.
Not sure what you're actually asking, but I'd suggest checking out Gale Bank's channel, as he goes deeply into the combustion process.
I'm with you Crand435. It would be nice to see some worked examples of modified Cummins powered trucks with larger than stock injectors.
