Adapting old BMW cooler lines to AN
Sistemas de plomería para deportes de motor
Discusión y preguntas relacionadas con el curso Sistemas de Plomería para Deportes de Motor
2440 Vistas
Hey is it possible to crimp AN rubber hoses to a connection like this? I'm gonna be using this for 8HP cooling
Yes you can use a hose clamp on that. For a neat look, consider using hose clamp covers (google "AN hose clamp covers").
Or you could have an AN fitting welded/brazed onto that tube, then you would use standard hose ends (google "weld on AN fittings for tube" for examples)
Wow thank you the reply. Is a hose clamp gonna really hold it?
I've never heard about hose clamp covers
What is the expected pressure? The tube has a bubble at the end, so I would think a proper sized hose and hose clamp would work fine something like 150 psi (10 bar) or less.
Oh okay. It's automatic transmission oil pressure so I don't think it will ever go over 100PSI
Alternatively you could cut off the rolled end and use a Hardline to AN adaptor
