AEM PDU-8 Pinouts
Sistemas de plomería para deportes de motor
Discusión y preguntas relacionadas con el curso Sistemas de Plomería para Deportes de Motor
2736 Vistas
As always, greetings to everyone from Panama and in advance, thanks for the help.
Ok I would like you to help me understand the description of the AEM PDU-8 pinouts.
In the image below file, you will see that pin 5 and pin 11 say (ground), I want to know if that is the ground of the device?
The other question is:
should i connect the two?
The next thing I don't understand is:
In the case of pin 10 and 16 the name is Config 3 and config 2, what does it mean? It also says that its function is (ground for Unit's 3,4,7 and 8), where should I connect that pin?
what is that for (ground for Unit's 3,4,7 and 8).
NOTE: I am not an expert with English. sometimes i use google translator my native language is spanish.
thanks for the patience.
Can't help at the moment, sorry, I've been out of the loop too long - for those that can, here is the full pin-out from AEM, of which that is a part - https://www.aemev.com/files/instructions/10-8300-EV%20PDU-8%20Instructions%20Rev3.pdf
Thanks for the complete pinouts, I have it, what I would like to know are the questions I asked in the first post
For the Config pins (10-16-24), it assigns an ID to the PDU-8 depending on which one is grounded. There's a table at page 7 of the manual that explains how to connect those pins.
If you are only using 1x PDU, you just leave those disconnected.
For the ground pins 5 and 11, I think they are the ground of the devices, but I never used this AEM product. I would connect both to ground.
Hope it helps,
Frank
I have been troubled, too. The documentation is not very clear, but . . . think of the PDU-8 as a RELAY. The big positive terminal = RELAY PIN 30. The two ground pins on the PDU-8 (5 & 11) = RELAY PIN 85 and go to CHASSIS GROUND. The output is in paired pins, so PIN 1 + PIN 2 are both switched together. There is a note in the documentation that you should use BOTH PINS for full current capacity. I've tried to show using HPA format. Attached is what I have so far. . . .
