4age 20v trigger setup ECU MASTER CLASSIC
940 Vistas
Hi... I need some help setting up the trigger for a 4AGE 20V on a ECU MASTER CLASSIC.... any help will be much appreciated.
Thanks
Do you have picture of the trigger ? I'm used to do 4AG 16V but not 20v.
On 16V I simply remove a tooth on the trigger wheel inside the distributor, so I can configure it as a cam toothed wheel with a missing tooth. (single sensor)
Attached is a the base map... can anyone let me know if my setup is wrong - 4age 20v with COP conversion and stock distributor as trigger. Thanks
  • E111-4age-Export-2-Rama.emu
