Ecumaster project with a PMU16 and a PMU16As
1328 Vistas
I have a Ecumaster project with a PMU16 and a PMU16As
What I would like to do is control outputs on both PDMS with 1 Motec Keypad
Doese anyone know if this is possible like we do with motec with a slave and master
pdm?
If its possible what is the way to set it up?
go to the ecumaster facebook group
It's certainly possible. I'm controlling an ECUMaster PMU16 on a Radical SR8 with a Canon keypad which uses J1939 (extended addressing).
Usually, keypads run on slower networks (250 Kbps), so you'll want to set one aside for the keypad so your other one can talk to the ECU and other devices at full speed (1 Mbps). Snag the MoTeC keypad reference, and away you go. I'd set it up so that the keypad talks to one PMU, and have that PMU pass on needed commands to the other.
