Crank reference position
1871 Vistas
HiJust confirming to make sure I have read the M1 help correctly.I am on a 60-2 crank trigger pattern (machined into the flywheel) triggering a hall effect sensor. The leading edge of the first tooth after the gap is at 60 degrees AFTER top dead center.So, do I enter -60 as the engine speed reference offset, with trigger on rising edge?Thanks in advance
