DBW setup on M1
3157 Vistas
Hi all,
This is my first post in the forum and I'm new to the tuning scene. I have a drive by wire for a Hayabusa engine ITB configuration. I have attached the actuator datasheet and I've been phoning up the local motec dealer for configuration but I was unable to reach anywhere so far. I looked everywhere to understand how to configure the feedfoward, deadband, PID and other associated settings for the DBW but it keeps fluctuating all over the place. I couldn't find a webinar or article how to properly configure DBW on M1 software. Can you point me out to a guideline on how to properly configure DBW in the absence of motec DBW pre-configuration?
Many thanks,
Abdulla
  • 102-102-00145-PACKAGE-REV-2.pdf
  • 102-102-00145_REV_2-IMAGE-1.pdf
  • 102-102-00145_REV_2-IMAGE-2.pdf
  • Actuator.pdf
Did you ever figure out anything? I can't find this information, either.
Unfortunately not
Hi,
For an ITB like that with an aftermarket controller, the recommendation is that it is sent to MoTeC to be calibrated correctly.
What PID numbers are you using? and what are your feed forward tables values?
