Developement license
1929 Vistas
Hi,
Have a technical question before i pull the plug on a developement license: does anybody know which packages are avilable in the library to start with?
thank you
Best regrads
Claudiu
I would confirm with your Motec dealer, but it used to be the standard GP packages only,. For example if you want to work with R35 not only can you not open it in Build, you have to pay for it separately, so I ended up with an M150 with a dev license and an R35 GTR license.
Now it is only an old version of GPA.
On a case-by-case basis it's possible to get other older packages. But MoTeC felt that too much of their intellectual property was being distributed for trivial fee. I would absolutely confirm what you want to do with the MoTeC Europe office.
Thank you for answers. I already use gprp so this would have been minimum base firmware for me. Will check with Motec europe see if new gprp firmware is available.
Good info David, thank you. I took the build course about a decade ago and haven't had time to make use of it.
When I work with 3rd party packages, things are often very out of date, features lacking, so what you said makes sense.
