FT86 cam inlet 1 position flutter
1818 Vistas
please anybody help me with this
i am using the stock v5 for automatic package from website
please enlighten me and make me sure again about how to set the offset
should i zero all the pid before making offset ?
i did unplug the solenoid when set the offset
when it happens... the car will stall and then dies
because the inlet cam bank 1 goes to -33
i tried to swap back to stock ecu... everything fine
PLEASE ENLIGHTEN ME
  • S1_6645_20210413_171446.ld
  • S1_6645_20210413_232856.ld
Nobody see this.. bump
