LTC NTK wideband
1899 Vistas
Hi,
Any ideas why my lambda signal will sometime be missing while the car is running ? looking at the LTC manager while the car is running shows me the sensor is turning off then it goes to heating, pumping and running. Obviously every time that process happens, the signal will be missing.
It also has a brand new sensor because I was suspecting the wideband at first.
Also both the ltc manager and m130 have the same CAN address (0X460).
thanks
