M1 Tune install and unistall
3188 Vistas
any chance to change M1 Tune location HDD or install folder or uninstall completely the program?
Hi Claudiu,
You can change the location of the M1 Tune install folder on the first install, but once it is installed, or you have other M1 software installed, such as M1 Build, then the file location is fixed. This is due to the inter dependencies with the Packages/Licenses/System Files/etc. and making sure that there is not multiple versions of the same files potentially being used.
You can change the location of the install directly by uninstalling all of the M1 software, restarting the PC, and then reinstalling.
Problem solved, reinstalled Windows as the registry would not delete :))
