M130 LTC-1 CAN signal to ADU5
1989 Vistas
Hi All,
I want to read the LTC-1 CAN signal from M130 with ECU-Masters ADU5. I have the correct CAN ID 0x460 and can see it in the CAN stream with Light Client.
Problem is, that the numbers in the frame are not moving when I test the O2 sensor, in M1 software it shows me the correct Lambda and it´s also moving.
Any idea what could be the problem?
LTC transmits a compound or multiplexed message, you possibly don't have that set up to be interpreted correctly.
This is how I would expect the ADU settings to look:
Hi Adam,
got it running, thanks a lot for your help
