Which Lambda should we use when we mix Port Injection metanol 50/50 Water with direct injection pump Gaz??
You don't mention what you goal is. But I think you can use Lambda 0.85 to Lambda 1.0. You can try different Lambda values on the dyno to determine what's best for your engine, but that should be a reasonable start.
Hello can you give us some more detail ?
