motec m130-pdm15 anti lag
699 Vistas
guys i need your help
im trying to configure the anti lag button on the keypad.
what are the steps needed to do configuration in the keypad. plus i have firmware GPR John reed
Is the Keypad controlled by the PDM, and the button presses sent over CAN to the M1? Or direct into the M1? Which JRR Firmware are you using?
its controlled by PDM15 & communication on CANBUS1
