Sensor inputs via CAN
2769 Vistas
I'm using the M150 FT86 package and there are a number of inputs available on the CAN Bus that I can't seem to add via to the ECU. The input only allows for a voltage sensor.
For example the Ambient Air Temperature channel can be configured as either a analog sensor connected to the ECU -or- by setting the CAN details. The Ambient Air Pressure channel however only has an option to configure this as an analog sensor connected to the ECU.
Is it possible to modify M1 Tune options to allow this data to be picked up from the CAN bus?
Screenshot attached better describing the issue.
  • CAN-v-Sensor-input.pdf
Hi Adrian,
This issue has been resolved in the new Toyota 86 Firmware that will be released shortly.
