Starter Control
1645 Vistas
Does the GPRP natively have starter control? It doesn't seem so but I figured I would ask.
Typical input would be clutch position and starter request, with obviously an output to toggle the state of a relay or solenoid.
Attributes such as min / max crank time(or revolutions) and disabling while engine is running etc.
None of the GP packages have this, but some engine specific packages might. This is normally handled in a PDM on the vehicles I've worked on.
Support for start systems is only in Targeted Packages, not in the GP Packages.
